Application Links SSL and Reverse Proxy
Rafal Niznik
Hello People,
I'm wondering if anyone can help me solve that problem because I have tried everything and sill cannot find proper resolution.
Currently I use this following configuration example With a reverse proxy I use Sophos WAF setup so all incoming connections that hits  WAN interface with query for kb.testdomain.com is redirected to internal confluence server and sd.testdomain.com redirected to Jira server
Confluence is currently configured to use SSL and port 8888  and Jira port 8889
All custom generated certificates and Root CA is already imported to default Java store as well as to keystore used by Confluence and Jira.
This is my current server.xml config:
Confluence:
<Connector port="8888" maxHttpHeaderSize="8192"
maxThreads="150" minSpareThreads="25" maxSpareThreads="75"
enableLookups="false" disableUploadTimeout="true"
acceptCount="100" scheme="https" secure="true"
clientAuth="false" sslProtocol="TLS" SSLEnabled="true"
URIEncoding="UTF-8" keyAlias="kb.testdomain.com" keyPass="something"
keystoreFile="/etc/ssl/cert.p12" keystorePass="something"
proxyName="kb.testdomain.com" proxyPort="443"
Jira
<Connector port="8889" maxHttpHeaderSize="8192"
URIEncoding="UTF-8" keyAlias="sd.testdomain.com" keyPass="something"
proxyName="sd.testdomain.com" proxyPort="443" />
At his point every user who is connected to those instances from external network is able to login edit pages add pages etc, so everything works fine.
Problem is when I want to create Application link between those to applications.
I was  able to add links but than I get this error  in Confluence:
Invalid OAuth signature
We couldn't connect to Jira, possibly because that instance is behind a misconfigured proxy.
and from Confluence
We couldn't connect to Confluence, possibly because that instance is behind a misconfigured proxy.
Here is my current application links setup from following applications
From Confluence:
Application URL sd.testdomain.com:8889
Display URL sd.testdomain.com
Server Base URL sd.testdomain.com
From Jira
Application URL kb.testdomain.com:8888
Display URL kb.testdomain.com
Server Base URL kb.testdomain.com
I have also tried point to server IP but result was that same.
So far I was able to figured out that if I remove from server.xml following lines application links works perfect
But after removing above lines every user that is connecting to those applications in not able to add, edit pages etc. anymore.
I have no idea what else could be done here to fix that issue and I will really appreciate if someone could help me solve that.
Raf
Rafal Niznik
Based URL and proxy setting are correct as follows:
proxyName="sd.testdomain.com"   and base URL is sd.testdomain.com
proxyName="kb.testdomain.com"  and base URL is  kb.testdomain.com
I run Confluence 6.13.0 and JIra 7.13.0 so there should not be  a issue.
So basically I'm able to get through first steps when creating AL between those two because they can see each other and fills up all field automatically
This is how I configure Application Links from Concfluence to Jira
Under application links on Confluence I enter following URL
https://sd.testdomain.com:8889
After clicking on create application links followed data is automatically filled out
You are creating a link from:
Display URL: https://sd.testdomain.com
Application URL: https://sd.testdomain.com:8889
Application: Jira
To this application:
Display URL: https://kb.testdomain.com
Application URL: https://kb.testdomain.com
Application: Confluence
After clicking on continue it redirect me to Jira and this is how it should be but than I get this messages:
It has not been possible to retrieve the required information from https://kb.testdomain.com Therefore the link cannot be created.
Click Continue to be redirected back to https://kb.testdomain.com Click Close to remain here.
I think this is because Jira is trying connect back to https://kb.testdomain.com instead of https://kb.testdomain.com:8888  and this is the problem here.
Later when I'm redirected back to AL on Confluence server I see this message:
Application Link 'SD' was created successfully locally but the reciprocal link was not created. Please review the configuration using the Edit option.
If I edit option on confluence and jire and select that same auth I see green arrows but at the top I see following message
We couldn't connect to SD possibly because that instance is behind a misconfigured proxy.
But proxy settings are configured correctly
So to me it looks like jira is trying connect back to https://kb.testdomain.com instead https://kb.testdomain.com:8888 and this where problem exists in my opinion.
Keep in mind the following server xml configuration
Confluence:
Jira
When I remove proxyName, proxyPort  and change base URL to kb.testdomain.com:8888 and sd.testdomain.com:8889 application links works perfect .
But than all incoming connection from WAF because there is not proxy configuration on server.xml  users are not able to add, edit, remote pages etc.
If I reverse and add proxyName, proxyPort than WAF connection works perfectly but Application Link is broken again and I have not clue how to fix that :-(
Diego
January 2, 2019
Hello here!
Rafal, this error is somewhat common when setting application links with a proxy between applications.
First thing we could check is if the Base URL is correct. The Base URL should be the same as your proxyName=**** setting in server.xml:
Configuring the Server Base URL - Confluence
Configuring the Base URL - Jira
After that, also check the Application Links compatibility Matrix and make sure that both Confluence and Jira are listed as compatible:
Application Links version matrix
As a general rule, you should ensure your applications are using the same major version of AppLinks to resolve any potential incompatibilities.
You can find more information on this behaviour here, in our article:
OAuth error oauth_problem=signature_invalid
If using the proxy for Application Links does not work, we can try to create an unproxied Application Link:
How to bypass a reverse proxy or SSL in Application Links
How to create an unproxied application link
Let us know if this helps your situation Rafal!
Rafal Niznik
January 7, 2019 edited
Still not luck so far.
Any other ideas?
mognem
September 3, 2020
this one helped me
I use contextpath, not subdomain, though
- created new connector on new port (step 1.)
accessed jira and confluence, locally using new port:
 http://localhost:<new port>/<contextpath>
changed base URL to http://localhost:<new port>/<contextpath>
created app links using http://localhost:<new port>/<contextpath>
changed base URL back to https://<domain>/<contextpath>
