All of our users, including admins, are unable to log into Confluence, they are getting an error on the login page saying:
This install has been up and working for a few months. Users are managed by JIRA. Everything was working last night. The server has not been rebooted. No IP addresses or port numbers have changed. The hardware is a 40 core Xeon server with SSD RAID and 128GB of RAM. CPU load rarely goes over 10% so I don't think it is a hardware resource issue. All users are able to login to JIRA without problems. All of the SSL certificates are good. The log for confluence is showing this error:
authenticateUser Directory 'Remote JIRA Directory' is not functional during authentication of 'username_here'
I tested the crowd authentication, I get a login prompt from my browser but I am unable to login to:
jiraserverurl.mycompany.com/rest/usermanagement/1/search?entity-type=user&start-index=0&max-results=1&expand=user
Any tips on how to troubleshoot this? All of the solutions I am finding there is at least admin access to the Confluence web UI.
This may help... Under User Directories in Confluence I see:
Synchronization failed. See server logs for details.
I got this error when testing the JIRA user director sync from Confluence
Test basic connection : Failed com.atlassian.crowd.exception.ApplicationPermissionException: Forbidden (403) Encountered a "403 - Forbidden" error while loading this page. client.forbidden.exception Go to Jira home
I am also encountering the same issue.
My JIRA and Confluence run on the same physical server.
I did recently move the server to another location. The IP addresses were updated.
The 403 error indicate there is comms.
Any help greatly appreciated
Hey, I found the solution here:
The problem came about because the IP address of my server had changed.
Thank you Kurt. After a server reboot I am able to log into my administrator account on Confluence but none of the other users are.
I tailed the JIRA log file and found that no events happen in the JIRA log during the Confluence login process. This is the error in the Confluence log:
I am still unable to login to:
I tried the following and I get a 404
confluenceserverurl.mycompany.com/rest/usermanagement/1/search?entity-type=user&start-index=0&max-results=1&expand=user
Hi Tim
welcome to the Atlassian community
Can you rerun your test from the confluence server. Looking at the atlassian-confluence.log might provide additional information
https://confluence.atlassian.com/doc/restore-passwords-to-recover-admin-user-rights-158390.html
should guide you in getting access by using the recovery_admin user
Hope that helps
Cheers
Kurt
