NGINX and Confluence
Tyler Hemingsen October 6, 2017
I have searched the documentation and many other's answers but I cannot get Nginx to work with Confluence.
Here is my /etc/nginx/conf.d/default.conf-
upstream tomcat {
server localhost:8090 fail_timeout=0;
server {
listen confluence.hemi.haus:80;
server_name confluence.hemi.haus;
listen 443 default ssl;
# ssl on;
ssl_certificate /usr/local/etc/nginx/ssl/nginx.crt;
ssl_certificate_key /usr/local/etc/nginx/ssl/nginx.key;
ssl_session_timeout 5m;
ssl_protocols SSLv2 SSLv3 TLSv1;
ssl_ciphers HIGH:!aNULL:!MD5;
ssl_prefer_server_ciphers on;
location / {
client_max_body_size 100m;
proxy_set_header X-Forwarded-Host $host;
proxy_set_header X-Forwarded-Server $host;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_pass http://localhost:8090;
location /synchrony {
proxy_pass http://localhost:8091/synchrony;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "Upgrade";
Here is my /opt/atlassian/confluence/conf/server/xml
<Server port="8000" shutdown="SHUTDOWN" debug="0">
<Service name="Tomcat-Standalone">
<Connector port="8090" connectionTimeout="20000" redirectPort="8443"
maxThreads="48" minSpareThreads="10"
enableLookups="false" acceptCount="10" debug="0" URIEncoding="UTF-8"
protocol="org.apache.coyote.http11.Http11NioProtocol"
proxyName="confluence.hemi.haus" proxyPort="443" scheme="https"/>
<Engine name="Standalone" defaultHost="localhost" debug="0">
<Host name="localhost" debug="0" appBase="webapps" unpackWARs="true" autoDeploy="false" startStopThreads="4">
<Context path="" docBase="../confluence" debug="0" reloadable="false" useHttpOnly="true">
<!-- Logger is deprecated in Tomcat 5.5. Logging configuration for Confluence is specified in confluence/WEB-INF/classes/log4j.properties -->
<Manager pathname="" />
<Valve className="org.apache.catalina.valves.StuckThreadDetectionValve" threshold="60" />
</Context>
<Context path="${confluence.context.path}/synchrony-proxy" docBase="../synchrony-proxy" debug="0" reloadable="false" useHttpOnly="true">
</Context>
</Host>
</Engine>
To run Confluence via HTTPS:
* Uncomment the Connector below
* Execute:
%JAVA_HOME%\bin\keytool -genkey -alias tomcat -keyalg RSA (Windows)
$JAVA_HOME/bin/keytool -genkey -alias tomcat -keyalg RSA (Unix)
with a password value of "changeit" for both the certificate and the keystore itself.
* Restart and visit https://localhost:8443/
For more info, see https://confluence.atlassian.com/display/DOC/Running+Confluence+Over+SSL+or+HTTPS
<Connector port="8443" maxHttpHeaderSize="8192"
maxThreads="150" minSpareThreads="25"
enableLookups="false" disableUploadTimeout="true"
acceptCount="100" scheme="https" secure="true"
clientAuth="false" sslProtocols="TLSv1,TLSv1.1,TLSv1.2" sslEnabledProtocols="TLSv1,TLSv1.1,TLSv1.2" SSLEnabled="true"
URIEncoding="UTF-8" keystorePass="<MY_CERTIFICATE_PASSWORD>"/>
</Service>
</Server>
Running on Centos 7
4 votes
Lars Olav Velle
October 8, 2017
Hmm this looks pretty OK to me.
Have you tried proxypassing to 127.0.0.1 instead of localhost?
Perhaps try disabling selinux temporarily: setenforce 0
-Lars
Tyler Hemingsen October 9, 2017
setenforce 0 worked! Thank you so much.
Steven F Behnke
October 6, 2017
What does it mean, "Can't get it working?"
Sorry, 502 Bad Gateway error when connecting via Nginx.
I can browse directly to the 8090 port.
Like ruslandudka likes this
