Our Confluence uses SSL and LDAP/AD and our Jira is non SSL and uses built in database user store. I have not been able to create an application link from Confluence to Jira it fails on creating the reciprocal link in Jira back to Confluence
What do I need to change or do to make this work?
Does Jira also have to use SSL and LDAP/AD?
Both are server versions.
Hi @Chad DeShaw,
What error do you get? Or is there anything in the log files? (INSTALLATION-HOME/logs/atlassian-jira.log or atlassian-confluence.log)
User Directories doesn't matter for application links and it should also work if one application uses SSL and one does not.
I will post the error in a minute but I have another question should check or uncheck I am an administrator on both instances if my users name is different on both instances?
You can check that, the other application will ask you for an admin account if your account does not exist there.
2019-01-03 13:35:11,672 http-nio-8080-exec-16 ERROR cdeshaw 815x425067x1 y0qhim 10.20.102.207 /rest/applinks/3.0/applicationlinkForm/manifest.json [c.a.a.c.rest.ui.CreateApplicationLinkUIResource] ManifestNotFoundException thrown while retrieving manifest
com.atlassian.applinks.spi.manifest.ManifestNotFoundException: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at com.atlassian.applinks.core.manifest.AppLinksManifestDownloader.doDownload(AppLinksManifestDownloader.java:198)
at com.atlassian.applinks.core.manifest.AppLinksManifestDownloader.access$000(AppLinksManifestDownloader.java:50)
at com.atlassian.applinks.core.manifest.AppLinksManifestDownloader$1$1.<init>(AppLinksManifestDownloader.java:127)
at com.atlassian.applinks.core.manifest.AppLinksManifestDownloader$1.load(AppLinksManifestDownloader.java:121)
at com.atlassian.applinks.core.manifest.AppLinksManifestDownloader$1.load(AppLinksManifestDownloader.java:118)
at com.google.common.cache.LocalCache$LoadingValueReference.loadFuture(LocalCache.java:3527)
at com.google.common.cache.LocalCache$Segment.loadSync(LocalCache.java:2319)
at com.google.common.cache.LocalCache$Segment.lockedGetOrLoad(LocalCache.java:2282)
at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2197)
at com.google.common.cache.LocalCache.get(LocalCache.java:3937)
at com.google.common.cache.LocalCache.getOrLoad(LocalCache.java:3941)
at com.google.common.cache.LocalCache$LocalLoadingCache.get(LocalCache.java:4824)
at com.google.common.cache.LocalCache$LocalLoadingCache.getUnchecked(LocalCache.java:4830)
at com.atlassian.applinks.core.manifest.AppLinksManifestDownloader.downloadInternal(AppLinksManifestDownloader.java:106)
at com.atlassian.applinks.core.manifest.AppLinksManifestDownloader.download(AppLinksManifestDownloader.java:84)
at com.atlassian.applinks.core.manifest.ManifestRetrieverDispatcher.getManifest(ManifestRetrieverDispatcher.java:43)
at com.atlassian.applinks.core.rest.ui.CreateApplicationLinkUIResource.tryToFetchManifest(CreateApplicationLinkUIResource.java:163)
... 3 filtered
at java.lang.reflect.Method.invoke(Method.java:498)
... 3 filtered
at com.atlassian.applinks.internal.rest.interceptor.NoCacheHeaderInterceptor.intercept(NoCacheHeaderInterceptor.java:13)
... 1 filtered
at com.atlassian.applinks.core.rest.auth.AdminApplicationLinksInterceptor.intercept(AdminApplicationLinksInterceptor.java:35)
... 1 filtered
at com.atlassian.applinks.core.rest.context.ContextInterceptor.intercept(ContextInterceptor.java:16)
... 15 filtered
at com.atlassian.plugins.rest.module.RestDelegatingServletFilter$JerseyOsgiServletContainer.doFilter(RestDelegatingServletFilter.java:154)
... 1 filtered
at com.atlassian.plugins.rest.module.RestDelegatingServletFilter.doFilter(RestDelegatingServletFilter.java:68)
... 41 filtered
at com.atlassian.applinks.cors.rest.CorsFilter.doFilter(CorsFilter.java:99)
... 3 filtered
at com.atlassian.web.servlet.plugin.request.RedirectInterceptingFilter.doFilter(RedirectInterceptingFilter.java:21)
... 53 filtered
at com.atlassian.jira.security.JiraSecurityFilter.lambda$doFilter$0(JiraSecurityFilter.java:66)
... 1 filtered
at com.atlassian.jira.security.JiraSecurityFilter.doFilter(JiraSecurityFilter.java:64)
... 16 filtered
at com.atlassian.plugins.rest.module.servlet.RestSeraphFilter.doFilter(RestSeraphFilter.java:37)
... 19 filtered
at com.atlassian.jira.servermetrics.CorrelationIdPopulatorFilter.doFilter(CorrelationIdPopulatorFilter.java:30)
... 10 filtered
... 4 filtered
at com.atlassian.web.servlet.plugin.LocationCleanerFilter.doFilter(LocationCleanerFilter.java:36)
... 26 filtered
at com.atlassian.jira.servermetrics.MetricsCollectorFilter.doFilter(MetricsCollectorFilter.java:25)
... 24 filtered
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:748)
Caused by: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.ssl.Alerts.getSSLException(Alerts.java:192)
at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1964)
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:328)
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:322)
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1614)
at sun.security.ssl.Handshaker.processLoop(Handshaker.java:1052)
at sun.security.ssl.Handshaker.process_record(Handshaker.java:987)
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1072)
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1385)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1413)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1397)
at org.apache.http.conn.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:396)
at org.apache.http.conn.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:355)
at org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:142)
at org.apache.http.impl.conn.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:373)
at org.apache.http.impl.execchain.MainClientExec.establishRoute(MainClientExec.java:381)
at org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:237)
at org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:185)
at org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:89)
at org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:111)
at org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:185)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:83)
at com.atlassian.sal.core.net.HttpClientRequest.executeAndReturn(HttpClientRequest.java:103)
at com.atlassian.plugins.rest.module.jersey.JerseyRequest.executeAndReturn(JerseyRequest.java:131)
at com.atlassian.plugins.rest.module.jersey.JerseyRequest.execute(JerseyRequest.java:113)
at com.atlassian.applinks.core.manifest.AppLinksManifestDownloader.doDownload(AppLinksManifestDownloader.java:165)
... 256 more
Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:397)
at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:302)
at sun.security.validator.Validator.validate(Validator.java:262)
at sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:324)
at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:229)
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1596)
... 278 more
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.provider.certpath.SunCertPathBuilder.build(SunCertPathBuilder.java:141)
at sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:126)
at java.security.cert.CertPathBuilder.build(CertPathBuilder.java:280)
at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:392)
... 284 more
2019-01-03 13:46:21,854 Caesium-1-2 INFO ServiceRunner [c.a.j.p.h.service.connect.InstallGlancesJobHandler] Running InstallGlancesJobHandler...
2019-01-03 13:46:21,854 Caesium-1-2 INFO ServiceRunner [c.a.j.p.h.service.connect.InstallGlancesJobHandler] There is no link to HipChat, no need to install glances.
2019-01-03 13:46:23,523 Caesium-1-3 INFO ServiceRunner [c.a.j.p.h.service.ping.RefreshConnectionStatusJobHandler] Running RefreshConnectionStatusJobHandler...
This error often appears when the SSL certificate is not imported in the keystore of the application.
Maybe this helps https://confluence.atlassian.com/jirakb/checking-ssl-keystore-for-imported-certificates-639238418.html
I am confused Jira Keystore or Confluence keystore? Because that was the Jira log I posted
You should check it on confluence if you are using SSL there.
The certificate is imported into the keystore on confluence. So I am still stuck.
Hi, I just did some research on this. The certificate must be imported also in the keystore the Jira Application uses. So can you try this please.
Here is the link to the FAQ where I found it https://confluence.atlassian.com/kb/ssl-and-application-link-troubleshooting-guide-719095282.html
I tried that too, the cert is also now in the Keystore on Jira
This is what I see in popup when the reciprocal link is attempting to be created
It has not been possible to retrieve the required information from https://sstconfluence01.ad.stauer.com:8443. Therefore the link cannot be created.
Do I need to restart Jira before this cert in the Keystore will work?
Does it matter that my Jira and Confluence use a different user data store?
OK I got it to work, I had to restart the Jira server after importing the certificate for it to work.
Thank You!!!
You are welcome, great to hear that it works now.
See inside
