How to build knowledge base articles from Servicedesk issues?
Catherine Stine September 16, 2025
We have hundreds of resolved service desk tickets that we would like to consolidate into knowledge base articles using our responses to the customer. Is there a tool for this? Can Rovo do this?
Christopher Yen
Hi @Catherine Stine , welcome!
There is an Atlassian Intelligence feature for suggested topics that has the ability to draft articles, though it does state it specifically looks at work items in the last 30 days
You can get to this under your project > Knowledge Base > Suggest Topics tab
or this URL if you plug in your site and project key
https://yoursite.atlassian.net/jira/servicedesk/projects/yourProjectKey/knowledge/suggested-topics
Like Christopher Yen likes this
Dan Breyen
Hi @Catherine Stine welcome to the community.  To do something specifically with JSM I found JSDCLOUD-16758 in Atlassian's Jira Site. You can vote for and watch that for updates if you'd like.
I was also thinking, since the Knowledge Base is a Confluence space, could you just use their API to bulk load some articles
I found the Create Page Post  as an example of creating a page.  You may have to tweak them for access after the fact.
Hope that helps.
Thanks, this is helpful.
