Hi all,
I need some assistance please, in our production environment I have user group that I cannot access. The process I follow is this:
Logon to Jira -> Settings -> System -> User Management -> Groups and search for the Group, this part works well.
Then when I select the group to open is I get the below:
No webpage was found for the web address: https://jira.site.com/secure/admin/user/ViewGroup.jspa?atl_token=BIQ2-X3X4-XXX-XXXX_1595fXXXX7165770292e0XXa499XX3_lin&name=Microsoft+Development+Team
Hi @Andrew Downs ,
Since you have already verified that you can access the group in your development instance, so the issue is specific to your production environment.
Here are some steps you can take to troubleshoot and resolve the issue:
<jira-home>/plugins/.bundled-plugins
<jira-home>/plugins/.osgi-plugins
<jira_install>/work
(just the contents, NOT the directory itself)<jira_install>/temp
(just the contents, NOT the directory itself)If still you are unable to identify the cause of the issue or resolve it, reach out to Atlassian Support for assistance.
Also, if you feel my input help you please accept the answer.
Bhushan
@BHUSHAN PATIL Thanks, the dev and prod go through the same load balancer.
I will try the plugin cache clear down and see if that fixes it.
As for the databae integrity jira integrity check comes back clean. But will do a sql integrity check just to make sure.
@BHUSHAN PATIL clearing the plugin cache made no difference.
it’s only a single group I seem to get the error on. Which is weird.
so here’s the facts I know:
1) Production Database restored over Dev Database works, so don’t think its corruption (dbcc checkdb confirmed)
2) Both sites go through the same load balancer and aside from the URL the configuration is the same
3) Clearing the plugin cache made
no difference
4) I have not done a full file level sync between prod and dev, so it might be something in Jira’s home or install folder causing issues.
I no longer have support with jira so I can’t raise it with them unfortunately.
