Hi All,
I have a use case where I am trying to auto fill few fields based on user inputs.
Say for example I have a custom field as "Country", there if I just type "IN" it should show all the suggestions for the country starting with "IN" like India, Indonesia, etc..
Can anyone help me in this. Or is this possible in JIRA with the groovy script.
ScriptRunner will not help you with you task. The only way to use Java Script but this solution is not mantainable.
@Alexey Matveev - I've read about other Javascript solutions that are similarly described as "not maintainable". What does that mean in the context of Jira?
-Payne
It means that it can have bugs and also it would be difficult for other developers to find you java script and make it work or fix it.
Gotcha; thanks!
Hi!
I've found a similar question here.
Have a look at Benji Mommen's script down there.
I haven't tried it but it looks as it may work.
