I would like to automate little bit subjects of my issues. For example:
User provides few informations in fields:
I want to achive subject like that:
{name} \ {location} \ {device}Result will be:
Sarah \ San Francisco \ Mobile phone
It is possible to achive?
Best regards,
Bartosz
You could also try the Automation Lite for JIRA and Automation for JIRA add-ons. Your use case sound fairly trivial.
You can use either Scriprunner plugin or JJUPIN plugin. Both of them let you add custom script in your workflow postprocessing were you can set subject line and much more.
