Disabling options under cascading select does not work
Rishikesh Karnik
Options keep appearing for cascading select, even after they're disabled in "Custom field" contexts.
For example : For a field named "Field" which has options A, B & C. Option A has cascading values in the next level called "a", "b" & "c". Option B has cascading values in the next level called "1", "2" & "3". Option C has cascading values in the next level called "Phi", "Gamma" & "Theta".
Even after disabling all values on both level 1 and level 2, the options still appear in the project linked in the context. Is there another way to do this? Am I doing something wrong?
Walter Buggenhout
Hi @Rishikesh Karnik,
This seems to be a known bug, that is currently being worked on. Watch JRACLOUD-78186 to stay informed when the fix will be released.
Hope this helps!
