How can I include linked issues in EMAIL
Anoop Wilson
February 23, 2012
We are using customised email templates for jira.I want to include the linked issue keys in JIRA email notifiaction.How can I do that?
Dieter
February 23, 2012
not sure yet if this solution works out of the box with Jira 4 but you could add a custom field provided by the Jira issue linker and searcher plugin (https://studio.plugins.atlassian.com/wiki/display/JILS/JIRA+Issue+Linker+and+Searcher) and use the value of this field using $issue.getCustomFieldValue(...) EDIT: The plugin does not work with JIRA 4+ but again the groovy script runner could help here: just create a new scripted field, which enumerates all links. There is already an example at https://studio.plugins.atlassian.com/wiki/display/GRV/Scripted+Fields that checks if a linked issue is not resolved yet
Dieter
February 23, 2012
Ah, justsaw this plugin is only available for Jira 3 https://plugins.atlassian.com/plugin/details/5000 Would have to be fixed first before my answer is helpful ...
Dieter
February 24, 2012
Found an alternate solution using groovy scripted fields, please check the example regarding unresolved linked issues at https://studio.plugins.atlassian.com/wiki/display/GRV/Scripted+Fields
