How do I add or edit Jira workflow categories?
Frank Pete October 19, 2016
I am now implementing a Stage Gate process in Jira. This is to force our organisation throught a commercial assessment and through a risk assessment and quality control before releaseing a larger development task for development.
In this process the cost benefit (commercial assessment) may lead to rejection of the development task.
The same applies for risk assessment.
For this purpose, I do need another workflow category 'Rejected'
3 votes
Nic Brough -Adaptavist-
October 19, 2016
You'll need to hack the core code of JIRA, those three categories are pretty much hard-coded into it.
Mahesh S
October 19, 2016
Nic, Are you people speaking about the 'Status Category' like 'To Do', 'In Progress' and 'Done'?
October 19, 2016
The question said category, so I assumed he meant category.
Mahesh S
October 19, 2016
Pretty confused what Frank is referring to as workflow category 'Rejected'. sad
Status Category or Workflow status?
October 19, 2016
He did not say status, he said category.  It's clear he doesn't mean project category, so it must be workflow category.
Like • Joe likes this
There are tree categories today. ToDo, In Porgress & Done.
Thinking about it, we can magage with the three as the process is actually
Evaluate = To Do
Evaluating process = In Progress
Evaluation done and task rejected = Done + new status = Rejected
Thanks anyway
Azfar_Masut
April 8, 2018 edited
It goes back to your definition of 'Rejected'
To Do, In Progress and Done is the highest level of the status category which should suffice.
Rejected is not vague/general enough to become a category. Eg.: I cant think of a status which could become under the category Rejected. However, Rejected can instead be categorized as Done, as when an issue is rejected, its usually the end of the issue cycle. And you set 'Rejected' as the resolution instead. (which is the reason why resolution option exist in the first place)
Alternatively, if your definition for rejected is that the issue is rejected, but pending for a review, you should set it the issue as either 'In Progress' or 'To Do'. Both could work depending to how you handle a 'Rejected' issue in your workflow.
Azfar_Masut
Azfar_Masut
How the hell do i delete comments here?? LOL
May 14, 2018
You don't.  It makes a mess of the conversation threads, so it's discouraged.
You can edit them and delete the content, but that's just rude.
Patrick Herrington
May 17, 2018
This really should be added in.  For instance, why is there not a testing category?  It could include Unit, QA, UAT.  "In Progress" depends on the scope you are looking at.
Like • 5 people like this
Marc Moroz
I agree with Patrick.  For development teams, it helps to have a way of grouping some statuses into buckets that represent Development, Validation, User Acceptance, etc.  Having all these as In Progress makes it hard for us to get good info out.
Like • 3 people like this
5 votes
Mahesh S
October 19, 2016
Please create a new status 'Rejected' (if not existing) from JIRA Administration-> Issues-> Statuses -> Add a new status. Add the new status to your workflow by referring this: https://confluence.atlassian.com/display/JIRA/Configuring+Workflow
Later, you can add this status to your agile board as well if required as https://confluence.atlassian.com/agile/jira-agile-user-s-guide/configuring-a-board/configuring-columns
Deleted user April 12, 2019 edited
Needed a Blocked Status for my issues. Achieved it thru this!
Would have been happy had i got a Category for this(so that i could define a specific color & symbol).. but gotta make do with whats available.
Paul Denize
April 20, 2018 edited
I agree these should be more flexible.  I'd love a category "Waiting on Third Party" making it clear the person it is assigned to is not the one doing the work but monitoring those that are.  And the colour of the status seems to be controlled by the category so having something that could stand out would be good too.
I read this whole thread "How do you...." and it seems full of why would you answers.  Nobody has yet said you do it by .... or you cant.
April 21, 2018
Yes we did, see the first answer.  Granted it's a couple of years old, but it's still right.
Pamela Rocamora
January 31, 2018
Hi I have the same issue as Frank. I want to add a new STATUS Category (like To Do, In progress and Done)
February 1, 2018
The original answer stands.
Like • Orlando Rondanelli likes this
Jo Vasev
May 1, 2019
Is this possible yet?
May 2, 2019
No, and it never will be - all these extra categories mentioned (so far) are really mostly status within "in progress" (and a couple are to-do or done)
Azfar_Masut
And as Nic said, not possible. It's hardcoded
