How do I set a task to "In Progress"?
It is in my Workflow but I cannot figure out how to move the task from "To Do" to "In Progress".
Thank you!
Do you see any button on top of the Issue view page that says Start Progress? Can you see the workflow used in the issue? May be the workflow associated with the Issue Type is not the one you want.
"Do you see any button on top of the Issue view page that says Start Progress?"
Well, I didn't before I created this post and until you mentioned it....so I checked again and there it is. Thanks!!
Great.
