How to Use the Post Function
Kristen Viscardi
it is possible to set a post function or a condition that says if the assignee field is “unassigned” that the person making the transition becomes the assignee?
Nic Brough -Adaptavist-
December 10, 2015
Definitely a post-function.  A condition blocks a user from starting a transition if the condition is not met.
You will need to find or write a post-function that will set the data for you at the end of the transition.  You can read the assignee field and say "if unassigned, set it to current user".  I'd use the script-runner to do it.
Kristen Viscardi
Steven F Behnke
December 10, 2015
Conditional Post-Functions are not a 'thing' in JIRA. Sometimes the programmer of a Post-Function programs the ability to write conditions or select simple conditions but that's outside of this conversation.
You should write your own post-function to achieve this goal.
To obtain this functionality without a writing a custom add-on, we must use conditions/post-functions as they exist within JIRA.
Use-case
Pressing Start Progress should assign the issue to the current user if it's unassigned.
Design
Create mutually exclusive transitions with opposite conditions, with identical functionality. They can have the same name to create a seamless experience.
Process
Transition to assign to current user if the issue is unassigned
  • Create a new transition, from Open to In Progress
    • Name it Start Progress
    • Add a Value Field condition
      • Assignee = null
    • Add an Assign to Current User post-function
Transition to leave it assigned to the current assignee
      • Assignee != null
To sum up...
You should now have two transitions. Only one can be visible at a time, and the logic performed will be as requested.
Steven F Behnke
December 10, 2015
Please note, the Value Field condition is provided by the JSUtil plugin, which is available for free for both JIRA Server and JIRA Cloud, thanks to Beecom.
