Hello all, I have the following Epic with this nested structure:
also, the Story AP-26 has a Task in a different project that is linked:
Now, I would like to see this linked Task in my Project Timeline. Is there a way to perform this?
Thanks for your time!
As I see you are on a premium tier.
You should use Plans option for this.
The project timeline only relates to the project, it can't incorporate issues from other projects.
