I'm using
When I do a reindex of JIRA I got the following error in the log-file:
2016-12-08 14:17:26,757 IssueIndexer:thread-9 WARN anonymous 847x35x1 11wbwdv 10.181.186.236 /secure/SetupImport.jspa [c.a.j.issue.index.DefaultIssueDocumentFactory] Error index
ing issue TOLERANCE-561: Dropping 'customfield_10965'
java.lang.NullPointerException
at com.atlassian.greenhopper.customfield.sprint.SprintHistoryEntryFactory.movedToSprintAfterStartDate(SprintHistoryEntryFactory.java:223)
at com.atlassian.greenhopper.customfield.sprint.SprintHistoryEntryFactory.lambda$null$22(SprintHistoryEntryFactory.java:188)
at java.util.Optional.map(Optional.java:215)
at com.atlassian.greenhopper.customfield.sprint.SprintHistoryEntryFactory.lambda$removeOtherNonActiveSprints$23(SprintHistoryEntryFactory.java:188)
at java.util.Collection.removeIf(Collection.java:414)
at com.atlassian.greenhopper.customfield.sprint.SprintHistoryEntryFactory.removeOtherNonActiveSprints(SprintHistoryEntryFactory.java:185)
at com.atlassian.greenhopper.customfield.sprint.SprintHistoryEntryFactory.getSprintChangeHistoryForIssue(SprintHistoryEntryFactory.java:154)
at com.atlassian.greenhopper.customfield.sprint.SprintHistoryEntryFactory.getSprintChangeHistory(SprintHistoryEntryFactory.java:52)
at com.atlassian.greenhopper.customfield.sprint.SprintCustomFieldIndexer.addDocumentFields(SprintCustomFieldIndexer.java:45)
at com.atlassian.greenhopper.customfield.sprint.SprintCustomFieldIndexer.addDocumentFieldsSearchable(SprintCustomFieldIndexer.java:30)
at com.atlassian.jira.issue.index.indexers.impl.AbstractCustomFieldIndexer.addIndex(AbstractCustomFieldIndexer.java:40)
at com.atlassian.jira.issue.index.DefaultIssueDocumentFactory$Builder.add(DefaultIssueDocumentFactory.java:84)
at com.atlassian.jira.issue.index.DefaultIssueDocumentFactory$Builder.addAll(DefaultIssueDocumentFactory.java:75)
at com.atlassian.jira.issue.index.DefaultIssueDocumentFactory.apply(DefaultIssueDocumentFactory.java:50)
at com.atlassian.jira.issue.index.DefaultIssueDocumentFactory.apply(DefaultIssueDocumentFactory.java:30)
at com.atlassian.jira.issue.index.DefaultIssueIndexer$DefaultDocumentCreationStrategy.get(DefaultIssueIndexer.java:556)
at com.atlassian.jira.issue.index.DefaultIssueIndexer$IndexIssuesOperation.perform(DefaultIssueIndexer.java:380)
at com.atlassian.jira.issue.index.DefaultIssueIndexer$IndexIssuesOperation.perform(DefaultIssueIndexer.java:369)
at com.atlassian.jira.issue.index.DefaultIssueIndexer.lambda$null$2(DefaultIssueIndexer.java:308)
at com.atlassian.jira.index.SimpleIndexingStrategy.get(SimpleIndexingStrategy.java:7)
at com.atlassian.jira.index.SimpleIndexingStrategy.get(SimpleIndexingStrategy.java:5)
at com.atlassian.jira.index.MultiThreadedIndexingStrategy$1.call(MultiThreadedIndexingStrategy.java:33)
at com.atlassian.jira.index.MultiThreadedIndexingStrategy$1.call(MultiThreadedIndexingStrategy.java:31)
at com.atlassian.jira.util.concurrent.BoundedExecutor$2.call(BoundedExecutor.java:68)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)I do not have any impact on my running system, but I would feel better if I could correct the system, that the error would not occur.
Thanks for any help.
Regards
Norbert
Hi Peter,
we will upgrade to JIRA 7.3 because we recognized that this version do not cause the error.
Thank you all.
Regards
Norbert
Hm, it seems that migration from JIRA 6 to JIRA 7 was completed with errors.
Unfortunatelly we do not use Agile and I do know how to migrate it.
Try to find documentation about JIRA Agile migration and follow guids
Hi Vasiliy,
here is a snapshot from table CUSTOMFIELD:
image2016-12-9 13:31:28.png
Seems for me, that is a custom_field used by JIRA Agile (formerly: Greenhopper).
Any idea?
Thank you
Norbert
Lets go further.
What is customfield_10965?
What type is it?
Is buid-in type or provided by some plugin?
Hi Vasiliy,
integrity check do not solve my problem!
Any other hint?
Thank you
Norbert
Try to execulte integrity check at first. Sometimes it helps.
