JIRA Setting Due Date with javascript
Duncan DAVIES April 26, 2012
Hi
I have read around the forums and found that I should be able to set the Due Date on my Issue Create screen based off the Priority using some custom javascript. The problem is, despite spending a few hours searching around, I can't actually find out where I can insert this javascript. I am running JIRA 4.4 if that makes a difference
RambanamP
April 26, 2012
add the javascript in due date field desciption of field configuration
