JQL query to filter issues that are blocked by
Geeta July 6, 2022
JQL query to filter issues that are blocked by.
Current in the sear issue the column "Blocked by" is showing blank which should not be the case
Fabio Racobaldo _Catworkx_
Hi @Geeta ,
did you try the following ?
issueLinkType = "is blocked by"
Obviously, value depends from your link configuration.
Hope this helps,
Fabio
Aron Gombas _Midori_
There is no such field "Blocked by", so clarify the field type first.
