When using /jira create on Slack, I am getting the following error message:
/jira failed with the error "operation_timeout"Is there an issue at the moment on Jira's server side? Thank you.
we have same issue ,please help
I'm having the same issue, how to fix it?
thanks
Hi @Santiago David ,
Yes, I can confirm there was an issue with the Jira Cloud for Slack integration earlier today. The problem on our end was resolved about 20 minutes ago (Dec 21, 17:50 UTC). You should be able to use the integration in Slack now and not receive the operation_timeout error. Give it a try!
Daniel | Atlassian Support
Works like a charm 👍
