Jira on chromebook
HaRsHaS_ V May 25, 2020
How do we use server version of jira on chrome book. it does show windows and linux..but chrome OS? did I miss anything here?
Nic Brough -Adaptavist-
May 25, 2020
Chromebooks are running Linux.
HaRsHaS_ V May 26, 2020
@Nic Brough -Adaptavist- thanks for the update.
could you please give more detail on this? Like how does this work?
Is it like using a command line or does the interface look like windows?
March 9, 2021
As a troll got my last post removed (it was rather terse), a better way to put it might be:
You will need to get command-line access to the Linux system you are running, and use the Linux installer to install the service.
I should warn you that Jira is not a light program, and Chromebooks are not usually server-class systems capable of running everything, you may not even be able to install it, and if you can, it may well be too slow to be usable.
