Hi
After upgrading to JIRA 7.0.10 and scriptrunner 4.2.0.6 one of the scripts in a workflow post-function fails with the following message
Failed type checking and we don't know why, it's our fault not yours @ line 1, column 1.
looking at the script I see indication as follows:
image2016-5-2 17:1:9.png
on the following line:
commentManager.create(issue, "Jira", "message string: " + reporter.getDisplayName() + ".\nBy script assignToBusinessUserOrRepoter.groovy" , true)
Please advise
"Jira" is a string, not an ApplicationUser object. You need to give it a user there. The commentManager API has changed and can't accept strings any more, so your script needs to be updated.
