jira permission to unlink issues
Bahar Çağlar
I am using issue linking (in jira 5.2.11). How can I disable delete this link button on the view screen? (image below)
Actually, the reason is that there is no settings in the permission scheme to allow/restrict users to delete issue links.
The only permission type is link issues.
Where is the permission for delete links?
Thanks.
RambanamP
November 26, 2013
you have already posted a same question here, pls avoid to post duplicate questions
https://answers.atlassian.com/questions/237357/jira-permission-to-unlink-issues
Christian Czaia _Decadis AG_
November 26, 2013
I'll quote your previous answer and close the other question as a duplicate:
rambanam prasad
· 14,809 karma · 20 hours ago
you can try with permission based on workflow steps,
http://www.j-tricks.com/1/post/2011/02/permissions-based-on-workflow-status.html
i have't teied that, you can try somthing like this
jira.permission.link.delete.group.1=some-group-one
Cheers
Mikhail_Kopylov
November 26, 2013
Unfortunately, this permission (Link Issues) rules both adding and deleting links.
You can do such workaround.
1. Create a plugin of web-panel type and put it into View Issue page.
2. In the velocity template of this plugin write a JS function:
<script type="text/javascript">
//your function here...
</script>
3. In your script find all <a> elements like this:
&lt;a class="icon icon-delete" title="Delete this link" id="delete-link_remote-10000" href="/secure/DeleteRemoteIssueLink.jspa?id=12100&amp;amp;remoteIssueLinkId=10000&amp;amp;atl_token=TOKEN"&gt;&lt;span&gt;Delete this link&lt;/span&gt;&lt;/a&gt;
and remove them.
