I run scriptrunner to create project as attached screen. It show the project created and I can query the data in project and project_key table of database jira.
Anybody know why? Any option missed?
Thank you very much!
And what exactly is the problem, beside not knowing about printscreen?
And you're sure you're using the admin projects view, or are you just looking at browse projects which filters you out if you have no browse permission to the project?
Try opening if it comes up
/plugins/servlet/project-config/XYZS
