Sign up Log in
Jira Workflow Toolbox - sum with nested expression on linked issues
KM November 6, 2019
Hi All,
I know that Jira Workflow Toolbox has a capability to define custom field as calculated math function. Moreover this function can operate on a list of linked issues e.g.:
sum(fieldValue({16901}, linkedIssues()))
But I cannot find a way to define such calculated field as nested match expression operating on selected 2 fields of lined issues e.g.:
sum(fieldValue({16901}, linkedIssues())* fieldValue({16902}, linkedIssues()))
I need it to calculate total spending as as sum of (cost * rate) of all linked issues.
Is there any way to workaround that ?
Thorsten Letschert _Decadis AG_
Hi @KM ,
and welcome to the 'parser zone'. :)
Your scenario is actually rather easy using the mathOnIssueList() function.
If you can ensure that cost and rate are always set on your linked issues, you can use:
sum(mathOnIssueList(linkedIssues(), ^{16901} * ^{16902}))
 The failsafe approach would read:
sum(mathOnIssueList(linkedIssues(), (^{16901} != null AND ^{16902} != null) ? ^{16901} * ^{16902} : 0))
The second expression calculates the multiplication only for issues in which both values (cost and rate) are set and otherwise includes 0 in the total for this issue.
Cheers
Thorsten
KM November 12, 2019
Awesome. Tnx for your help.
KM
You're welcome. Just as an additional note: if my explanation solved your problem, could you please mark the answer as correct?
