Have a look on calendar
Frédéric BENEAT January 9, 2020
I want to have visibility on all my calendars Trello. One place to see all the deadlines that I have set on different tables and projects. Can you help me ?
Samie Delebo - Your Gal at Gliffy
Hi Frédéric!
I'm not the biggest Trello expert, but what I've done is sync all my boards to a personal calendar. (iCal)
You could also try using the new Butler tool to create a rule for every board that any card assigned a due date would be duplicated into an additional master calendar board. Sort of a weird workaround.
I hope someone else in the community has an easier way to pull this off. :)
Frédéric BENEAT January 15, 2020
OK, I'm going to use i cal. Should I download it from Trello?
I think these instructions will walk you through it best:
https://help.trello.com/article/829-using-trello-with-google-calendar
