Currently, we use the JMCF plug in to get a Weighted Shortest Job First score calculated from 4 other number fields. We want to be able to show this in our Roadmaps, but it looks like calculated fields are not supported in Advanced Roadmaps. Are there any workarounds or are there plans to provide that functionality?
We are using Data Center if that changes it
Not sure this will help (seeing as you use a plug-in to provide the WSJF fields....if they are not supported, then.....) But we created our own fields and use Automation for Jira to do the math. These fields are supported and can be added to a Roadmap Plan. it works a treat! Like a spreadsheet with formulas.
But we are on premium Cloud,
Perhaps, you could create a supported WSJF custom field and copy the data over to that field to show on the roadmaps?
Hi @Curt Holley .
I currently use the JMCF Add-On to have a field that shows me the number of how many times the "start date" field has been changed.
I can´t use this field in the advanced roadmaps though. Could you please describe your way to transfer this field somehow to the advanced roadmaps? Thank you!
