Advanced Roadmaps Review Changes Is Slow
Pam Fick-Gerster
We are running Advanced Roadmaps version 3.28.0. My plan has 1 project with 54 issues.
When reviewing changes, we are experiencing performance issues. It took 90 seconds to commit 12 changes.
On my plan, I created 5 issues and updated 7 others. When I Review Changes and then click Save Selected Changes in Jira, a popup box for each new issue appears and I have to click Create. This makes the process much slower.
Questions:
1. Why does the dialog box come up for each new issue creation? The box only has three fields on it; project, issue type, summary.
2. Are there any known performance issues for saving changes?
3. What is the expected time to save changes?
DJ (61 429 578 954) January 25, 2022
@Pam Fick-Gerster I have the same issue ! when creating many new items in the plan I am prompted with a "Set Required Fields" pop up for each new item and it seems the only thing it is showing for you to review is the "Summary" field which is mandatory but already populated.
It would be good that only "Required Fields" that are NOT populated are raised to be addressed and if all mandatory fields are already populated then just skip the pop up box.
