Sign up Log in
Anyone else frustrated by Portfolio and its inability to use sprints created in another board?
Peter Davies November 4, 2019
I have linked epics to initiatives and have portfolio active. But it doesn't appear to link sprints together.
Separately it doesn't seem to be able to pick up epics in kanban boards.
Help????
Lachlan G
November 7, 2019
Hey Peter,
To start with what version of Portfolio are you using?
You should be able to use sprints from multiple boards, you just need to have that board set up as an issue source for your plan.
Can you clarify what you mean by linking sprints together? Do you want the epics and initiatives to share the same sprint?
The tool should be able to pick up epics from kanban boards could you raise a support request at https://getsupport.atlassian.com/
Lachlan
Portfolio for Jira Server Team
Peter Davies November 8, 2019
Issue sources were not set up. There has now been a decision to remove the kanban initiatives from our view of portfolio so now I have no visibility of what is happening there.
I have to say that I find the Portfolio view of very limited value for a scrum team.
