Cant Start Automation for JIRA
Steve Josue
When we attempted to start Automation, we get two separate failures between selecting "Sample Project" or "Existing Project" Project.
When selecting "Sample Project" we get the error, " An unknown error occurred. Please contact Code Barrel Support. TypeError: Cannot convert undefined or null to object".
When attempting to select "Existing Project" we get the never ending Spinning wheel.
-Steve Josue'
Mirek
I think that overall this "Cannot convert undefined or null to object" was related to a bug which was fixed in 8.0.3 version (released two days ago - 29.07.2022)
https://jira.atlassian.com/browse/JIRAAUTOSERVER-502
If someone could not upgrade to this version the workaround is to access Automation for Jira directly from the Project Settings (or downgrade as @Dan Stefan Teletin did)
Mirek
Hi @Steve Josue
Did you tried on a different browser? What is the result? Same? Is this the same behavior for all users?
Steve Josue
Yes, both Chrome and Edge display exactly the same.
Thank,
-Steve
David Jansson July 11, 2022
Hi @Steve Josue
We face the same problem
Did you find a solution? Uninstall and use scriptrunner for jira which actually works?
-David
Dan Stefan Teletin
July 25, 2022
Hello, the issue is still not solved, (and it is not a problem with the browser).
I am currently on "Automation for Jira" version 8.0.0
And I am running Jira software server  v8.20.11 if it matters.
Do we have any solution or a workaround? Do we need to upgrade or downgrade the installed Jira automation app version?
Is there a task opened for this defect so we can track it?
Dan Stefan Teletin
July 26, 2022
Hy, I managed to make this work by downgrading it to v7.4.2 and it works fine on the Jira server version 8.2.0
Like • Amine Tanboura likes this
