I am new to using Portfolio and I am wondering if when you have finished all of the project level releases of a CPR is the CPR supposed to auto fall off in or what is the expected workflow for the no longer needed CPR at the Portfolio level? It is a little noisy if it stays. Thanks.
Hi James,
The expected workflow in this case would be to delete the CPR once it is completed. At the moment there is no other workaround for this.
There is a feature suggestion for this issue here https://jira.atlassian.com/browse/JPOSERVER-1918 which you can vote on.
Portfolio Server Team
