Custom field values are still available in my plan
Laura Gerlev Hansen October 6, 2020
Hi community!
I have a Jira Server instance with the addon Advanced Roadmaps for Jira.
I've created a number of custom fields, which I show in my Plan.
The trouble is that I have some "select list (single choice)" custom fields, where I have disabled some options, but these options are still possible to choose from the plan view.
If I edit the issue directly in the Jira project, it only shows values which are still enabled, but in the plan view I get all options, even if they shouldn't be possible to choose.
We have done a re-index of our instance since disabling the values.
Lasse Langhorn
October 7, 2020
Hi @Laura Gerlev Hansen and @Joseph Chung Yin
I have submitted a request to Atlassian support.
I will let you I they can confirm and reproduce this bug.
Regards
Lasse Langhorn
Joseph Chung Yin
@Laura Gerlev Hansen Hi Laura - We have also reproduced your issue (We are on Jira DC 8.9.1 with AR 3.29.1).  I would recommend you to submit a support case with Atlassian support for further assistance.  It seems it is a bug in AR.
@Dave - Atlassian are you aware of this reported issue with AR?
Best, Joseph Chung Yin
Jira Functional Lead, Global Infrastructure Apps Team
Viasat Inc.
Laura Gerlev Hansen October 7, 2020
Hi @jtyetukuri
Thank you for the help! I'll reach out to Atlassian support.
Dave
October 14, 2020
Sorry for the slow response @Joseph Chung Yin - I was not previously aware of this issue - it looks like this has been raised as this bug: https://jira.atlassian.com/browse/JPOSERVER-2871 - I'll aim to get this on our short term roadmap to be fixed.
