Differences between JPD and Advanced Roadmap
Bakhtawar Tanveer March 13, 2024
Hi guys,
I am struggling with creating a plan for our new project and can't decide which Jira product is better for my requirements. I'd like the plan to be clear and easy to be presented to all kinds of stakeholders so that they can understand the whole pic.
I was told to explore Jira Product Discovery but also heard about the Advanced Roadmap. Now got a bit of confused.
Any key differences between the two product? Or any suggestion for their use case?
4 votes
Zoey Wang
March 13, 2024 edited
Hi @Bakhtawar Tanveer
It truly depends on what kind of activity/plan you are working on.
Here is an article written by Atlassian team, though it’s two years old, it takes time for users to understand and deploy in the real world.
https://community.atlassian.com/t5/Jira-Product-Discovery-articles/The-relationship-between-Jira-Product-Discovery-Jira-Software/ba-p/2186837
"JPD helps with Discovery of problems for instance whereas Advanced roadmap as a feature of Jira Software focuses on the Delivery side of projects. "
A little summary here
   JPD  Advanced Roadmap
 Focus  Discovery of problems/ideas etc - why  Delivery of projects - how
 Stakeholders  Different levels  People committing to the project on the delivery level
Type Product Feature (of Jira Software)
Cost Creators - billable Available in Jira Premium and Enterprise
Thanks for that!
3 votes
Ollie Guan
Hi @Bakhtawar Tanveer ,
As a product leader, I will choose to use JPD for annual and quarterly OKR splits, product planning, and investment return analysis.
After everything is in place, I will work with the technical team to use Jira Plan(advanced roadmap) for portfolio project management, resource scheduling, correlation analysis and dependency analysis.
Bakhtawar Tanveer March 14, 2024
Pretty helpful. Thanks!
Like • Carrie Bonnell likes this
Michelle Melancon
April 4, 2024
@Bakhtawar Tanveer  Hey there!
When we're helping customers roll out AR one of the big questions is where the work is coming from in your organization. JPD fits in nicely in the starting spot for vetting out the ideation phase and prioritizing deliverables based on data points.  Those ideas can then be converted to initiative or features to be planned and tracked in Plans.
We're working on a solution guide on this topic. I'll keep you posted when It's available but if you have any other questions let me know.
Shelley Richardson September 9, 2024
@Michelle Melancon so there's no way to use the Initiative as is in JPD in the Plan?  We have to create a duplicate card called Initiative in another project?  I'm just trying to track the best step forward to using all the Jira tools we're paying for, any help would be great, thanks!
Like • Michelle Melancon likes this
Michelle Melancon
September 11, 2024 edited
@Shelley Richardson You can convert an idea by selecting 'create a delivery ticket.' The idea can then be converted to any issue type you choose and created in any project you select. Its still trackable in JPD.
In the example above, depending on the scope of work, the issue could be an initiative or feature issue type. You can also link an idea to an existing issue in Jira.
Let me know if I can help with anything else!
https://support.atlassian.com/jira-product-discovery/docs/create-a-jira-issue-from-jira-product-discovery/
