Don't find Portfolio for Jira
Almatrodi June 17, 2018
Dear Sir/Madam,
I tried many times searching for Portfolio for Jira in the marketplace inside Adds-On, but I was unable to find it at all!.
Please help me.
Regards
Abdurahman Almatrodi
Thomas
June 17, 2018
Hi @Almatrodi,
Portfolio for Jira Server is currently not compatible with Jira 7.10, a new version of Portfolio will be released in the following days adding that compatibility. Sorry for the inconvenience!
Thomas
Almatrodi June 17, 2018 edited
@Thomas
Thanks for clarifying. Is it possible to work with current version and update it when new version is ready?
Thomas
June 18, 2018
Downloading from the Marketplace and Installing manually the current version of Portfolio on Jira 7.10 is currently unsupported, it might work but could result in some error or unexpected behavior.
So while it is not impossible, I can not in good conscience recommend it and would instead advise waiting a few days for a new version of Portfolio to be released.
Thomas
@Moses Thomas
I tried this. Unfortunately, I got a message about not compatible.
Btw, I am using my own server.
Thanks for your reply.
Moses Thomas
@Almatrodiwhich  version of  Jira do you use,  please see image, when you  go to  the link which  i have sent, download and install  the right version  supported for  your Jira instance.
Best
@Moses Thomas
I've downloaded version 2.13.3 for my Jira server 7.10.1. Still getting message in red IMCOMPITABLE!
Don't find version for my version.
