Hide 'Canceled' issues from Jira plan
Alvaro Landin September 11, 2023
Good afternoon,
I need to know how to hide any kind of issue marked as 'Cancelled' from a Jira plan. I still want to see doe example tasks or stories marked as 'Done' inside an ongoing epic but I will like to hide does issues marked as 'Cancelled'.
Thanks in advance!
Carla Ann Rowland
September 11, 2023
It depends on how your plan is pulling the data from your Jira project. If it is a filter then have the criteria status not in (canceled, cancelled) from within the filter. You can also edit the filter on your plan board filter  plan filter snapshot.png
 for statuses--- click on status and removed checkmark from canceled and leave the check mark for the other Done category statuses.
