×Hello Experts,
we are currently evaluating Portfolio,
We would like to manage product implementation projects, and for that we need to define milestones
Can you please advise how can I define them in Portfolio?
Naama
Your milestones are effectively your release dates, you could create epics for certain stages of your project and assign these to releases which match your milestone dates.
That isn't a very good approach. There can be a lot of issues tied to a milestone in different ways including:
Those "stakes in the ground" can be moved independently of other works and may or may not impact a release. They may be a date that a tool arrives from a 3rd party or almost any other thing, and there can be many of these special dates in a release cycle.
I can see that using releases can do some of the same thing, but conceptually it is better to keep a "release" with a specific meaning and a milestone with its own specific meaning and not muddy them together.
Just some examples of dates("milestones") that are not releases.... feature/code freeze, trade show dates, scheduled maintenance on environments... to work around things, you have to be able to see them alongside your release schedule.
It is just to add in the Gantt view similar to today´s day a vertical line for specific milestones indicating the iD or the name as a visual representation of the milestones. In 2014 it was posted the following suggestion with 125 votes: https://jira.atlassian.com/browse/JPOSERVER-71
Please solve this issue and enable milestone visualization and add suitable features as requested with ticket JPOSERVER-2825. I really don´t understand how a tool can be called advanced roadmap without adding the possibility to visualize milestones. At least it should be possible to show naming of the fix versions/releases, create abbreviation of the name and blend in/out milestones as needed.
Hi, has this matter been solved? Any other suggestion, how to add milestones in Portfolio without using releases? Thanks in advance :)
I do not see that it has been resolved. Key dates and milestones within a release are a useful mechanism.
The issues is still not resolved unfortunately!
There is always a need to see dates different than release dates in a project plan.
