How do I add more board to an existing plan in Portfolio?
Nicole Downes
Once a plan is setup in Portfolio, how can I add more boards/projects to the plan?   I have forgotten or picked the wrong ones.
Martin Suntinger
September 26, 2016
In the plan configuration (reachable via the |...| next to the plan name) Go to "Issue Sources" > Edit Sources and you can add another board/project there or re-include / exclude versions and issues.
Nicole Downes
Thanks for your prompt response. That helps a lot
