I'm trying to do the above. On the Jira help resource, the initial steps are as shown below. However, I cant find where "plan" is in the "plan > Releasese > + Create release" mentioned in Step 1 below
Anyone has experience with this?
Create cross-project releases by following these steps:
Correct. Plain Jira considers versions to be completely project objects. A version in one project has nothing to do with one in another, even if the name is identical. Portfolio layers some linkage and commonality across those.
No we don't. Sounds without Portfolio, this is not possible, is that correct?
Thanks, I appreciate the response!
Have you got Portfolio installed and licenced?
