How to add a release to an existing plan
Lee Cash
January 7, 2021 edited
I created a Jira Plan and associated a Release (Fix Version) to it. So far so good. I would now like to add another existing Fix Version to the Plan. I don't know how to do this. I can't seem to see how this is possible in the configuration. I can "Create a Release" but this is not the same as linking in an existing Fix Version release.
Am I missing something obvious here?
Thanks in advance,
Lee
3 votes
Dave
January 7, 2021
Hi @Lee Cash ,
If you use the cog icon to configure your plan you'll be able to modify the data sources for the plan.
This is currently slightly different on Cloud and Server... on Cloud you want to use the "View releases" button that you'll see under the "Exclusion rules" configuration.
On Server selecting the releases to include in the plan is on the last step of the wizard that you use to edit your issue sources.
I hope this helps!
Dave
Lee Cash
Ah! I didn't see the "Next" button. It wasn't intuitive (to me at least), that you're essentially going through the create wizard again.
Thanks, Dave, you've been extremely helpful.
Lee
Like • Dave likes this
Dave
January 10, 2021
No worries @Lee Cash , glad I was able to help!
