How to periodically restart Jira?
Chris
September 22, 2021
Hi dear community,
we are running Jira 8.13 on Ubuntu and our test-system periodically stops working due to out of memory.
As this is only happening on our testsystem and basially only afects myself, I would like to have a quick and easy solution. I tried to stop and start jira manually, which solved the issue.
I tried to implement a cron-job to stop and restart jira every monday night, but it doesn't work - well the event triggers, but jira does not stop, nor restart.
# Jira Service jeden Montag Morgen um 00:00 stoppen
0 0 * * 1 /etc/init.d/jira stop
# Jira Service jeden Montag Morgen um 00:03 wieder starten
3 0 * * 1 /etc/init.d/jira start
Logs are not very helpful.
Sep 19 23:58:40 cl1app-06-t snmpd[1148]: Connection from UDP: [10.50.70.65]:54899->[10.50.70.206]:161
Sep 19 23:59:01 cl1app-06-t CRON[6966]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 60 2)
Sep 20 00:00:01 cl1app-06-t CRON[6972]: (root) CMD (/etc/init.d/jira stop)
Sep 20 00:00:01 cl1app-06-t CRON[6971]: (CRON) info (No MTA installed, discarding output)
Sep 20 00:00:40 cl1app-06-t systemd[1]: Starting Discard unused blocks...
Sep 20 00:00:40 cl1app-06-t systemd[1]: Started Discard unused blocks.
Sep 20 00:02:05 cl1app-06-t snmpd[1148]: Connection from UDP: [10.50.70.65]:65020->[10.50.70.206]:161
Sep 20 00:02:05 cl1app-06-t snmpd[1148]: Connection from UDP: [10.50.70.65]:65036->[10.50.70.206]:161
Sep 20 00:02:15 cl1app-06-t snmpd[1148]: Connection from UDP: [10.50.70.65]:65223->[10.50.70.206]:161
Sep 20 00:02:20 cl1app-06-t snmpd[1148]: Connection from UDP: [10.50.70.65]:65316->[10.50.70.206]:161
Sep 20 00:02:25 cl1app-06-t snmpd[1148]: Connection from UDP: [10.50.70.65]:58052->[10.50.70.206]:161
Sep 20 00:02:30 cl1app-06-t snmpd[1148]: Connection from UDP: [10.50.70.65]:58151->[10.50.70.206]:161
Sep 20 00:02:35 cl1app-06-t snmpd[1148]: Connection from UDP: [10.50.70.65]:58239->[10.50.70.206]:161
Sep 20 00:02:40 cl1app-06-t snmpd[1148]: Connection from UDP: [10.50.70.65]:58428->[10.50.70.206]:161
Sep 20 00:02:45 cl1app-06-t snmpd[1148]: Connection from UDP: [10.50.70.65]:58513->[10.50.70.206]:161
Sep 20 00:02:50 cl1app-06-t snmpd[1148]: Connection from UDP: [10.50.70.65]:59024->[10.50.70.206]:161
Sep 20 00:02:55 cl1app-06-t snmpd[1148]: Connection from UDP: [10.50.70.65]:59113->[10.50.70.206]:161
Sep 20 00:03:00 cl1app-06-t snmpd[1148]: Connection from UDP: [10.50.70.65]:51711->[10.50.70.206]:161
Sep 20 00:03:01 cl1app-06-t CRON[7002]: (root) CMD (/etc/init.d/jira start)
Sep 20 00:03:01 cl1app-06-t CRON[7001]: (CRON) info (No MTA installed, discarding output)
Sep 20 00:03:05 cl1app-06-t snmpd[1148]: Connection from UDP: [10.50.70.65]:51800->[10.50.70.206]:161
Any help is very much appreciated.
Chris
October 7, 2021
Hi everybody,
we did an upgrade to version 8.19.1, which solved the issue. No periodical restart nessesary.
Unfortunately, version 8.19.1 has a bug, which affects us:
Tinker Fadoua
@Chris
You shouldn't have this problem. I won't suggest you to restart the service every week. There are instances running 24/7
If you are seeing an Out of Memory issue that means your system doesn't meet may be the required configuration. Please check the following doc:
https://confluence.atlassian.com/adminjiraserver/jira-applications-installation-requirements-938846826.html
Let me know if you have any questions
Best,
Fadoua
Chris
September 22, 2021
Thank you very much for your replay. Our live-system is running 24/7 without any (memory) issues.
I will check your link. But as I indicated, this only affects me and I cannot allocate more ressources to the system. A simple reboot would do the trick. :-)
Like • Tinker Fadoua likes this
Tinker Fadoua
Sometimes too much can create a problem as well. This is from experience.
Best way is to check Atlassian System requirements. It is very helpful.
All the best,
Fadoua
