Is it possible to prevent update access to custom fields in plans
Dave Cuff August 27, 2020
Hi.  We have a plan that shows some custom fields however we don't want the users to update these fields in the plan as the are calculated by a formula.  Is this possible?
Hi ÅžÃ¼krü
Thank you for the response.  Much appreciated.  Looks like I have to by a plugin.
Regards
Dave Cuff
Şükrü TURGUT August 27, 2020
There are 2 options;
1- Create your own custom field ( it is the long way )
2- Buy plugin ( easy way but expensive way :)
Regards
You can user Project Permissions for this.
In Permissions -> Edit Issues
give this permission to allowable users or groups.
Or rebuild a permission scheme and use it.
Thanks however I only want to prevent edit access to certain fields not the whole issue?
SERVER
VERSION
8.5.4
