Managing Shared Epics Across Departments – Best Practices or Plugins?
behzadnaz
October 2, 2025
I’m looking for a way to manage Epics that are shared between two or more departments in Jira. Here’s the scenario:
  • An Epic starts with Department A, and once their part is done, it moves to Department B.
  • Each department has its own team members and may want to assign tasks/stories to them.
  • We need a single overview that shows:
    1. Which department currently “owns” the Epic?
    2. The progress of tasks within each department.
    3. Status of the overall Epic.
My questions:
  1. Is there a recommended way to set up workflows or dashboards in Jira for this scenario?
  2. Are there any plugins/add-ons that make managing cross-department Epics easier?
  3. Any best practices for tracking department-level progress while keeping everything in one Epic?
Thanks in advance for any suggestions!
Danut M _StonikByte_
Hi @behzadnaz,
I don't see an easy way to track this with Jira's out of the box tools.
But in case you want to try an app, this can be easily done by using the Pivot Table & Pivot Chart gadget offered by our Great Gadgets app.
With this gadget you can display multi-dimensional stats in form of tables, heatmap tables or charts of various types.
Here is how this app will address your needs:
1. Which department currently own the epic
In this example the progress is by number of tasks in each status category. You can also display progress by sum of story points or by status instead of status category.
For this to work, the tasks must also have the department field set on them.
3. Status of the overall epics
This gadget is capable to display similar stats for initiatives, themes or features (- two levels above the Epic in he Jira issue hierarchy.
For how to do this, see this article: https://community.atlassian.com/forums/App-Central-articles/How-to-display-the-progress-of-Epics-or-Initiatives-in-Jira-or/ba-p/2858840
If you need any help or maybe a demo, feel free to contact us at support@stonikbyte.com.
Danut.
Rahul_RVS
Hi @behzadnaz
Welcome to the community !!
Not sure if this can be achieved out of the box in Jira. If you are open to try out a mktplace solution for this need, I can suggest
Agile Tools
The app allows you to view your project issue hierarchy (cross projects as well) created with issue links as well or standard Jira hierarchy or both in a tree view. You can view %complete progress at each parent level. It sums up the time tracking fields, story point or numeric fields at each parent level. The app can be added to a dashboard as well.
Disclaimer : I am one of the app team member
Valerie Knapp
Hi @behzadnaz , welcome to the Atlassian Community and thanks for your post.
A plugin we have implemented in the past to show cross-project scope and its progress is BigPicture.
They have a demo instance which you can check out here - https://softwareplant.com/demo-bigpicture/plugins/servlet/softwareplant-bigpicture/#/box/ROOT/o/hierarchy
You can see the work breakdown structure and the progress at each level (iteration in this case).
BigPicture is quite a powerful plugin and might be a bit overkill for what you are trying to achieve. If you have questions about this tool, you can reach out to the vendor to ask them - https://marketplace.atlassian.com/apps/1212259/bigpicture-portfolio-resource-management-for-jira?hosting=datacenter&tab=support
Best wishes
