Metrics for release Forecasting
Ashish Nagpal June 13, 2019
I would like to see release/ Epics predictability based on three scenarios Standard, worst and best or something similar. Has anybody tried forecasting similar way
Danut M _StonikByte_
Hi @Ashish Nagpal,
With our Great Gadgets app for Jira & Confluence you can generate burndown/burnup charts with forecast for Jira project and epics.
However, it only displays one scenario, based on average velocity. But it this is so important for you, we could consider adding the worst & best scenarios.
If you have questions, please don't hesitate to contact support@stonikbyte.com.
Danut.
Earl McCutcheon
June 17, 2019
Hi Ashish,
I am not aware of any method or add-on that could provide an automated method to achieve a multi scenario approach or best to worst case timelines; but for a manual approach you can look into setting up Multiple scenario planning, and in each of the scenarios adjust the weighted items of the scheduling factors (i.e. rank, estimates, capacity, dependencies,  etc...) to get the varying level of comparison, best to worst on the plans layout, and after reviewing commit the one that looks to be the most achievable.
Using this approach as your primarily looking at the Release variable you could set up one scenario with a "As early as possible" start date and a "dynamic" release date and the second with the optimal fixed dates and the third with a conservative fixed dates to compare the three variable plans and see if there are any conflicts in the schedule on each scenario.
Also check out the documentation for "Scheduling behavior" that goes into more detail on how the item weighted items are calculated.
Earl
