×Hi all,
When defining a theme to an initiative, it is supposed that child items (epics and stories) get the same theme (https://confluence.atlassian.com/jiraportfoliocloud/using-the-themes-report-828785348.html). In my case this is not always happening, i need then to go through all the epics and stories to check if the theme is correctly set (which is extremely painful, i'm talking about more than 1000 items). Any ideas?
rgds,
Romain
Hi Romain,
We were looking into the problem but wasn't able to replicate the issue on JIRA Portfolio Server. Since you have included Cloud version of the documentation, could you confirm if you are on Server or Cloud?
Cheers, Syauqi
Hi romain,
In that case, I've raised a support ticket to gather more information which requires your HAR-file which you can generate by following this guide here: https://confluence.atlassian.com/kb/generating-har-files-and-analysing-web-requests-720420612.html
We also need to know which version of Portfolio you're using.
Could you provide the information over there?
Cheers, Syauqi
Ok thks, we'll provide you with this information starting from next monday (sorry for the delay).
Romain
