×Hi I created a new portfolio plan for a JaaS project and selected the releases defined in the project as well. However portfolio displays only 'Later'
Hi @Amrita Nair
In the Issue Source of your plan, are you using the JaaS project as source or a board?
By default, during the plan configuration, you need to manually select the releases you want to import, otherwise the plan won't import them.
Besides that, when you use an project in the issue source instead of a board, if you create a release in this project after creating the plan, it won't be imported in your plan.
If you want to do that, you'll need to use a board as Issue Source instead.
Let me know if this helps :)
Gabi
Hi Gabriele , Thank you for the response. I tried creating a new portfolio and it now works. However, I am curious about the difference between importing project and importing boards. What is the key diference? I also noticed it asks for creating project team and board team (resources). Both the teams are one and the same in my case. Which one should I be using ?
