×We have been in the process of adopting Advanced Roadmaps. We are on Data Center. We started to play with Program views which roll-up multiple Plans. I noticed today that issues won't display on the timeline view in a Program when the issue in the plan is using roll-up dates. Has anyone ran into the same issue? If so, are there work arounds?
It is my understanding the functionality of roll-up dates at the Program view is not available for the product, this feature is only associated at the plan level.
However, you may want to contact Atlassian Support (https://support.atlassian.com) for further inquiry and possible solutions on the product.
Sorry.
Best, Joseph Chung Yin
Jira/JSM Functional Lead, Global Technology Applications Team
Viasat Inc.
I think this is more the issue - I noticed today that issues won't display on the timeline view in a Program when the issue in the plan is using roll-up dates. - do you know why that would be?
I wasn't sure myself whether this was the actual issues that created the rollup in the Plan or if the issue in question (possibly an epic or above) is just not appearing.
Issues above the epic are displaying on the Program view, but only if the Target Start/End is populated. If the Target Start/End is a roll-up date then the issue doesn't show. We were thinking about creating an automation to populate the Target Start/End based on the roll-up date but are not sure where that roll-up date is being stored and if it is even something that can be referenced via automation.
Is there something in your issue sources that would constrain that? something relating to those fields like a time period??
From what I understand standard issue types are not included in the program version of AR.
