Start/End dates according to release
Artur Franczuk July 29, 2021
is there any quick/simple/automatic way to put start/end dates according to release and the fixversion the issue is assigned with?
Leon July 29, 2021
Specific to roadmap topic, I think the "auto schedule" button is to do what you ask asking. But you need to set it up the way adv roadmap suggests.
Artur Franczuk August 17, 2021
I gave it a test and it seems it's working ;) thx!
Curt Holley
Hi @Artur Franczuk
Not sure if you are using Jira Cloud or not, but assuming you are, then using Automation would be the way to do this.
Setup a rule along the lines of:
Trigger = Field value changed (field being fix version), on edit and create.
Condition = When Fix version is not empty
Action = Edit issue (and set up the relevant date fields as follows)
{{triggerIssue.fixVersions.startDate.format("yyyy-MM-dd")}}
{{triggerIssue.fixVersions.releaseDate.format("yyyy-MM-dd")}}
Curt Holley
Footnote:
You may wanna add in conditions around not updating the dates if already populated?
Up to you,
Just thought I'd add this, as the above will overwrite any existing dates, which might be what you want, or not.
looks great, however unfortunately I'm using server version. Hope your post will help others anyway
Jan Života October 10, 2024
It does, thank you very much! :)
atlassian, confluence administration certification, atlassian certified professional, confluence admin for cloud, atlassian learning, confluence training, confluence certification exam, confluence cloud admin, admin credential, atlassian certification
Become a certified Confluence admin today! 📖
Stand out as a skilled Confluence Cloud administrator. The Confluence Administration for Cloud certification proves you can configure permissions, manage site and space settings, and monitor activity—ensuring secure, effective collaboration for your team.
