Status report including finished Stories?
Sandra Kawamoto
Is there a way to have a simple report with all stories of one product? I would like to know percentage of done tasks in each story. I would also want to list the ones full completed (100%). Thanks!
Tarun Sapra
June 4, 2018 edited
Hello @Sandra Kawamoto
Per Story if you want to see progress percentage then it is something which you might not find out of the box.
If you are using porfolio then you can track progress in percentage
https://confluence.atlassian.com/jiraportfolioserver/status-and-progress-tracking-715263088.html
Though portfolio doesn't have any supported reporting gadgets as of now.
Structure plugin also supports it
https://wiki.almworks.com/display/structure/Progress+Column
Other reporting plugins like eazyBI and dataplane arsenale also support your requirements.
Sandra Kawamoto
Thank you very much for answering @Tarun Sapra! I'll check your links.
Janis Plume (eazyBI)
June 13, 2018
Hi, Sandra,
You can create reports like this using the eazyBI app (add-on) for Jira.
Please, find here in the eazyBI demo account a Gantt chart showing the progress of each issue in the hierarchy by the completion of the tasks from lower hierarchy level:
https://eazybi.com/accounts/1000/cubes/Issues/reports/78204-issue-epic-gant-chart
You can also build in eazyBI the Jira Portfolio hierarchy and have reports by the Jira Portfolio hierarchy.
Find here more example reports for the project overview:
https://eazybi.com/accounts/1000/dashboards/5942-project-overview
Kindly,
Janis, eazyBI support
