Sign up Log in
Story not showing correct sprint
Alison Clough
We have a story in a plan in AR (Data Center) that is not showing as aligned to the active sprint and the points aren't showing in the sprint progress in AR. The story was started two sprints ago and rolled over twice. AR is showing the alignment to the past two sprints and is using those dates to drive the start start and target end. We've tried assigning the correct sprint to the story. This fixes it initially. But when you commit the change in Jira the plan reverts back. The story in question is definitely aligned to the active sprint and showing as completed. Any ideas what might be happening?
SERVER
Upcoming Advanced planning Events
