Sign up Log in
Story with multiple fix versions is not scheduled in portfolio when one fix Version is selected
Liz_Pat
February 11, 2019 edited
I have stories with multiple fix versions. I have noticed that all the stories with multiple fix versions do not appear on the schedule until I select both fix versions in the portfolio plan settings.
This is a big problem because the plan needs to go off of one single fix version, regardless of what other fix versions might be associated--not both.
The story scheduling factors shows:
This issue is not appearing in the schedule. This may be because:
  • You need to recalculate your plan
Phil February 12, 2019
Hi Liz,
did you find a solution?
If not: are the target dates calculated automatically when excluding one of the fix versions (releases) in the issue sources? What happens when you type in the target dates manually?
Phil
Liz_Pat
I've tried a few times to tinker with it by issue sources, I too thought there had to be a way. Basically it was the same issue with each way I tried to include or exclude the issues. Even if I do get it working with a jql filter in between it guts my core use case for Portfolio if I can't filter smoothly between scenarios and fix versions. So I put that workaround on hold -- high effort and (for me) low value.
Upcoming Advanced planning Events
