aggragation of estimates?
BEN FRIEDMAN
i didnt find in the documentation - when having an advanced roadmap, does it have the option to display each story's original estimate and for the epic to aggregate that?
ive seen that its available by story points, but haven't seen for estimates.
Dave
January 7, 2021
Hi @BEN FRIEDMAN ,
Advanced Roadmaps has the ability to "roll-up" certain data from an issue to its parent. This includes the ability to roll-up estimates, see https://confluence.atlassian.com/advancedroadmapscloud/rolling-up-values-to-parent-issues-998651148.html
This should provide the aggregation you're looking for. With the roll-up enabled you see the value for the issue side-by-side with the aggregate value from it's children.
It's important to note that you have to specify an estimation unit for you plan, either story points, hours or days - the plan won't allow you to see all 3 units at once.
I hope this helps!
Dave
