how to configure xray manually
Namrata Toraskar
February 21, 2025
I am stuck on summary while configuring Xray as I didn't get option to add issue type automatically. how to go about from here
Timoti Sburv
you’ll need to configure them manually. Go to Issue Types Mapping in the left-hand menu and assign the appropriate Jira issue types to Xray entities like Test, Test Set, Test Execution, Test Plan, etc. If you don’t have these issue types in your Jira project, you may need to create them first in Jira Settings -> Issues -> Issue Types and then map them in Xray.
Once mapped, make sure to check Test Types to ensure that manual, generic, or Cucumber tests are correctly set up. If you're still not seeing options, verify that your project permissions allow changes to issue types.
Francisco Fonseca (Xray)
February 24, 2025
Hi @Namrata Toraskar ,
Adding to what @Timoti Sburv said, please check our documentation for more assistance here: https://docs.getxray.app/display/XRAYCLOUD/Quick+Setup
It appears you are trying to setup a team managed project, feel free to go through that section on the link I provided.
Best, Francisco
